Inlay Material http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=54003 |
Author: | Colu41 [ Mon Mar 08, 2021 1:20 pm ] |
Post subject: | Inlay Material |
I'm still researching and setting up my first build, and I wanted to try a few different things. For the fretboard inlays, can they be a form of metal? Or will that interfere with the fretwire? |
Author: | jfmckenna [ Mon Mar 08, 2021 2:19 pm ] |
Post subject: | Re: Inlay Material |
Do you mean like will it cause some corrosion or something? I don't think that would be a problem. |
Author: | ballbanjos [ Mon Mar 08, 2021 2:22 pm ] |
I've inlaid metal on several banjos--nickel silver mostly, since it engraves nicely. It was pretty common in the late 19th century. Dave |
Author: | Clay S. [ Mon Mar 08, 2021 4:05 pm ] |
Nickel silver would be a good choice for inlays - it is relatively easy to cut, polishes up well and isn't too expensive as it contains no silver: "Nickel silver, a range of alloys of copper, nickel, and zinc which are silvery in appearance but contain no silver. Its composition varies from 7 to 30 percent nickel, the alloy most widely used being 18 percent nickel silver (18 percent nickel, 62 percent copper, 20 percent zinc)." (britannica.com) Many woodwind instruments use nickel silver for the keys. https://www.amazon.com/Nickel-Silver-Sh ... B00F1OC1FM |
Author: | mountain whimsy [ Mon Mar 08, 2021 4:20 pm ] |
I've used knife handle mosaic pins and brass wire for side dots. Lots of variety and look great. ![]() Sent from my SM-G973U using Tapatalk |
Author: | ballbanjos [ Mon Mar 08, 2021 4:31 pm ] |
Those do look good. I've done side dots out of small brass tubing with colored epoxy in the middle--banjos frequently have colored veneers under the fingerboard, and I'd color the epoxy to match the veneer. Dave |
Author: | ballbanjos [ Mon Mar 08, 2021 4:37 pm ] |
Here's a resonator uke I built back in the 80s. Spun my own cones and everything back in those days. But the inlay at the end of the fingerboard is red epoxy in an aluminum tube. Sort of a bigger version of the side dots I've done out of metal, Dave |
Author: | Skarsaune [ Mon Mar 08, 2021 8:21 pm ] |
mountain whimsy wrote: I've used knife handle mosaic pins and brass wire for side dots. Lots of variety and look great. ![]() Sent from my SM-G973U using Tapatalk I’ve got some mosaic pins in the bench for my current project. |
Author: | Ruby50 [ Tue Mar 09, 2021 9:12 am ] |
I have used sterling silver and copper - under a finish they retain luster Ed M |
Author: | Barry Daniels [ Tue Mar 09, 2021 11:07 am ] |
I've used brass but it will tarnish, even under a finish. Aluminum is better because it looks like silver but will not tarnish. |
Author: | Colu41 [ Tue Mar 09, 2021 1:37 pm ] |
mountain whimsy wrote: I've used knife handle mosaic pins and brass wire for side dots. Lots of variety and look great. ![]() Sent from my SM-G973U using Tapatalk These mosaic pins were exactly what I was thinking about. I was a knifemaker and have a lot of materials left over including some of these pins. They also make ones called "Decrofil". They are brass/copper tubes filled with colored epoxy or phenolic. Give it a really nice look. Well thanks guys that definitely answered my question |
Author: | bftobin [ Mon Mar 15, 2021 11:56 am ] |
I have also seen powdered metals that can be mixed with epoxy to fill like inlay. |
